QUICK ?stion - STUDS
Old Jun 2, 2005 | 11:55 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Can you get a stud with different diameters to adapt to different axle/wheel combination? What I mean is, I have a ford 9" /w ford axles. The studs are of a greater diameter. Do they sell studs of that diameter at the base but a smaller diameter @ the lug spots? I'm almost about to downscale these suckers on the lathe. But please post a solution. I don't wanna do that!
Old Jun 3, 2005 | 05:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not really....
They sell lots of different sorts of studs, and you can go through the Dorman catalog or something and maybe come up with what you need, by sheer luck; but there aren't alot of varieties of "swap" lugs, with specific combinations of mis-matched stock sizes like that.
Best thing to do, is to re-drill the axle, with the holes you need to fit the lugs that you need to use, in the wheel pattern that fits the wheels you want to use.
F-body-fan
Jan 12, 2023 01:49 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
