700R4, can I use the 4th gear pressure switch for TCC lockup?
Car: 89 IrocZ
Engine: L98-ish
I heard it could be done, but wanted to know what's involved...i/e wire from the 4th gear pressure switch to the TCC solenoid so when tranny shifts to OD the TC will lock.
Is this doable? Any issues with doing this like decellerating with the TCC engaged?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Chances are your 4th gear switch is N.C., not N.O., so you couldn't use it directly, but you could use a relay. If you don't mind changing things, you could replace the 4th gear switch with a N.O. one and rewire.
Car: 89 IrocZ
Engine: L98-ish
Thanks for the reply. I'm looking for a way to get around buying a lockup kit.
What's the 4th gear pressure switch used for? Nothing internal to the tranny is it?
Car: 89 IrocZ
Engine: L98-ish
Thanks again
Very cool.
Do you think there would be any potential issues decellerating with the TC locked?...Say cruising at 60-70, then coasting with the TC locked up until the downshift occured?
Very cool.
Car: check
Engine: check
Transmission: check
Originally posted by 8Mike9
Thanks again
Very cool.
Thanks again
Very cool.
Leaving the TCC locked in 3rd felt like I was driving a stick car. Whole different scenario.
RBob.
Car: 89 IrocZ
Engine: L98-ish
Lol, I'll ask around a bit more. I know the TC stays locked for a bit when I let of the gas in my IROC, but only for a few seconds...don't know if there's a longevity reason for it, or just because that's how they designed it.
Thanks again, now go out and enjoy the 3-day weekend!
Car: 89 IrocZ
Engine: L98-ish
Originally posted by RBob
I've left the TCC locked in 4th during decel and I could hardly tell. This is because the over-run clutches are not engaged in 4th. So I don't see a problem with that.
RBob.
RBob.
Thanks.
About 90% of all 4th gear switches are normally open, & that is what you need for a 4th gear lockup. You will need the GM lockup vacuum solenoid & plugin, to make this work. At medium to slightly light throttle openings, the TC clutch will stay locked up. At very light or WOT throttle openings, the clutch will unlock.
Car: 89 IrocZ
Engine: L98-ish
Thanks Dana,
The tranny is out of a '91 or 92 RS, should be the same as my '89, huh? I have the Helms for my 89 with the fluid diagram/schematic.
Gm style vacuum switch for lockup
I'm using a switch like this to lock up my 200-4r. It work great. No lock-unlock-lock-unlock cycles at all. The pigtail
was hard to find, however. I have a hot wire to a N.C.
brake switch to a two terminal N.O. 4th gear pressure
switch then to a 700-r4 style grounded TCC lockup
solenoid. The vacuum line for the vacuum switch is connected to full vacuum port at the intake manifold. Pushing the brake pedal or accelerator opens the lockup circuit.
http://www.smpcorp.com/web_app/catalog/images/VX2.jpg
TA8487
Aug 16, 2015 12:21 PM
dhonda200
Aug 11, 2015 11:50 PM
