T-5 shifter question
Old Jun 3, 2005 | 09:10 AM
MadMikeyL's Avatar
I have a project I am working on and I need to know how to separate the shifter handle (long steel shaft part) from the shifter mechanism itself. If anyone knows how to do this, please let me know. Thanks.
Mike
Old Jun 3, 2005 | 10:17 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Don't know that you can on the factory shifter. It's rather easy (two bolts) on the Hurst and Pro 5.0 after market shifters though....
Old Jun 3, 2005 | 02:11 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
When i did this I heated it up whith a torch intill it started smokeing then i twisted and pulled intill it was set free. The bushing is rubber and was not damaged bad to reinstall clean well and get some good A+B apoxey and you are good to go I do not know the correct way of doing this or if you can get a new bushing, Good Luck
Old Jun 7, 2005 | 02:19 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-5 shifter question
Mike
Unthread it.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
