Inspection Shroud Missing
Old Jun 4, 2005 | 08:03 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
My "inspection shoud" is missing. This is the piece that cover the torque converter and a fly wheel gear (?). How important is that piece? I've been without it for over a year at this piont.
Curious,
Old Jun 4, 2005 | 08:20 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i've never run one on my camaro, although i suppose at night a critter could hop up there
Old Jun 4, 2005 | 09:39 PM
Cadillac's Avatar
That would suck to be that critter!
Old Jun 8, 2005 | 11:26 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I would consider that piece necessary. It keeps debris out of that area and protects those components from weather (water splashes on your torque converter hub and rear main seal surface)... Put one on, you can find one at the junkyard or at the dealer..
Old Jun 8, 2005 | 11:17 PM
Cadillac's Avatar
I think I agree. I was a little surprised to see the exposed gear and torque converter exposed to the world when I was under the car last.
I'll add it to the junk yard list.
Old Jun 9, 2005 | 07:47 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I haven't had one on my car for over 3 years. And my clutch is exposed to the elements. But it is a good idea to have one, I just don't car enough to put it on.
Old Jun 9, 2005 | 07:55 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
You can get a cheap shiny metal one off eBay for cheap. Bling bling! On my silly 700r4 my inspection cover bolts all broke off so having wasn't an option so I had had to upgrade to a T56
Old Jun 9, 2005 | 09:17 AM
thirdgen88's Avatar
Car: 1995 Corvette
Make sure you get one for a 153 tooth flexplate... Plenty of them out there are for the big 168 tooth, and won't fit the starter.
Old Jun 9, 2005 | 10:14 AM
rsn932's Avatar
they are 6 dollars new from the dealer. id get one just to be safe.
Old Jun 10, 2005 | 08:04 AM
JPrevost's Avatar
Car: 91 Red Sled
Failed inspection because mine's been missing for 4 years. Just now they felt like hassling me about it after spending $$$ to try and get it passed last time.
The part isn't that important. Having water/mud splash on it doesn't do the TC harm but the flexplate teeth might not like it.
The ONLY time I had an issue with mine was when I was in a rush and splashed into a large puddle that hadn't frozen over yet. Well the next day it wouldn't start and when I got it jumped I heard the ice shatter and the car started right up.
Other than that, never had an issue. Infact I bet my transmission temps have been lowered now that the TC can expell a lot of it's heat.
Old Jun 10, 2005 | 08:41 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I have never run one either on mine and has been fine. Although i can not get one to fit either. (had a spare one from my 84 camaro) and it will not fit around the starter. Was going to put the starter on the engine from the original engine, and the bolts did not line up for the starter. not to mention the starter is about 1/3 size larger than the other.. So basically i am stuck. Took it to a dealer and they were stumped by it too. Probably came from the fact the engine that is in it now had a th350 on it, and everything was just dandy. put a 700r4 on it with the original size starter and it won't fit.. lol
Lbibb
May 5, 2016 12:00 AM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
armybyrd
Sep 26, 2015 03:37 PM
