The 7.5 rear end sooooo weak !
Old Jun 5, 2005 | 11:24 AM
stroked1990RS's Avatar
Car: 1988 formula 350
Axle/Gears: 373
what is the best thing to do ..... besides a 12bolt or ford 9'' swap
to make this rear end good for drag racing ...11 sec car ?
Old Jun 7, 2005 | 11:16 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
Weld the Axel tubes to the Pumkin.
There are braces out there that connect to each tube. I don't know how good they are & if their weld on or bolt on. Supose to reduse Axel Tube Flex.
Get a Good Posi (Eaton for Ex.). I'm not saying there the best.
But, even doing all this, the Ring & Pinion are still the weakest Links. If you are going to use the 10 bolt for Dragging, get some Richmond Gears. From what I read & heard, there made to with stand some punishment. Maybe they will hold up for awhile.
I would upgrade the Yokes & U-Joints also.
Old Jun 7, 2005 | 06:08 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I had richmond gears in my old 10 bolt, still did not help too much. (lasted a little longer)
best thing is an eng. that is more rev. happy that way you don't bit the track too hard on your launch but, even at 11's I don't know
Old Jun 7, 2005 | 09:28 PM
Axle/Gears: 373
thanks
i seen a place online who sell a detroit locker for the 7.5 i am thinking of getting that ? also i was thinking about a mini spool ?
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
