Any T5s in 4th gens from factory?
Car: 1989 RS Camaro
Did any 4th gen camaros come with a T5 transmission from the factory, b/c i've heard a few times about a T5 being pulled from a 4th gen camaro with a V6, did GM ever do this from the factory?
Car: 1989 RS Camaro
ok, well what is the particular torque rating for these transmissions, because i have a 95' LT1 im putting into my camaro and i want the trans to somewhat hold up, will this 4th gen V6 T5 work with a V8 if i get the correct bell housing, any help is appreciated
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
It won't have the correct V8 input shaft, so you'd have to use a special clutch, but otherwise yes it will work. If it's a WC T5 it should be rated around 300 lbs/ft, but that depends on the gear ratios. That rating is for the V8 performance ratios (2.95/1.94/1.34/1.00/0.63). I'm not sure what ratios the 4th gen V6 T5 has. You can probably find out at Tremec's website www.ttcautomotive.com
