Gear mesh ?
Old Jun 17, 2005 | 10:24 PM
rjmcgee's Avatar
Gear mesh ?
Had to pull my rearend apart to replace the posi unit and thought maybe someone could tell me how the gears are looking so far. These have a couple thousand miles on them now and I thought the mesh pattern looked real good. Is it? Now is the time to change something before I put it back together.
Old Jun 17, 2005 | 10:25 PM
rjmcgee's Avatar
Hopefully the pics are clear enough to see it.
Old Jun 18, 2005 | 05:17 AM
ede's Avatar
ede
i'd worry more about measurements than the contact pattern. you need marking compound to see where the gears are running.
Old Jun 20, 2005 | 11:11 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Looks good from what I can make out, but ede is right you'd really need to show the pattern with marking compound, and measure backlash with a dial indicator.
Old Jun 21, 2005 | 01:04 AM
rjmcgee's Avatar
Thanks, backlash was .008" if I recall correctly.
Old Jun 21, 2005 | 06:53 AM
.005"-.010" is the spec, so you're right there.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
