Clanging and banging noise
Old Jun 19, 2005 | 03:30 AM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
While driving home tonight, I decided to play around a little and punched it from a 20 roll, but as soon as it shifted into 2nd, I heard this loud popping noise. Now when I give the car any form acceleration, their is a loud, almost hammering, type noise coming from under the car and it only grows more apparent with added rpm's. I just had the rear end rebuilt and added Richmond 3.73. BTW, it doesn't make any noise on turns. Could it be a bad u-joint or did my rear end get chewed up by an improper install? Any input is greatly appreciated.
Old Jun 19, 2005 | 09:39 AM
sp63
Guest
Posts: n/a
broken trans mount?
everytime mine shifted it would slam into the bottom of the center console.
Old Jun 19, 2005 | 12:57 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
It does it all the time, not just on shifts. I checked the trans mount and it seems to be fine.
Old Jun 19, 2005 | 03:50 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Any ideas?
Old Jun 20, 2005 | 03:14 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Sounds like either a broken tranny mount, and/or motor mounts. Have someone shift the car from park to drive and reverse while holding the brake, while you watch the engine and tranny. If the engine moves anything more than just a fraction of an inch, it's the motor mounts. If the tranny jumps off the cross-member, it's the trannsmission mounts. If neither does these things, check the u-joints for play.
Also, hope to hell that it is one of those three things, cause if it's not, you're gonna have quite a bit of fun.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
