lock up question
Old Jun 21, 2005 | 02:49 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
lock up question
i recently converted to carb and was looking for a quick way to have my trans lock up so i installed a switch.
now it seems to be with the switch off and i come to a light the car will bog down to about 500 rpm then come back up to normal but with the switch on it does not do that.
am i right to assume that power on to the switch locks it up or is t the other way around killing power to the switch lockes it up?
Old Jun 21, 2005 | 03:01 PM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
yeah i have the same transmission 700r4 i'm carbed too, and was wondering the sort of same here cause my lock up is gone now cause of recent wireing issues. what wll it perform like with it not hooked up
Old Jun 21, 2005 | 04:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you hooked it up according to the tech article, putting the switch to "on" actually grounds the circuit to complete the path, thereby locking the torque converter.
The power goes through the brake light switch, so with the brake on the power to the lock-up solenoid should be cut, even if your new switch is "on".
How exactly did you wire this up?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Cameeeero
Sep 18, 2015 04:00 PM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
