TH350 w/ speed vendor overdrive vs. built 700R4
Old Jun 21, 2005 | 11:02 PM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
Transmission: 700-R4
Well, tranny isn't going to last long, I got everything running again and the tranny slips. I took it to the shop and ask them about a rebuild, they told me they didn't want to rebuild it and see me in another couple of months. I guess 700-r4's aren't built to take 500hp all day, they recommended a bullet proof th350 with a speed vendor overdrive, I don't exactly understand how it works but they said they could build one that would last me years and could handle upwards of 900hp without a slip.
Old Jun 22, 2005 | 10:15 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah sure, and they make out on that deal like a bandit. What you're dealing with is a trans shop that doesn't like 700R4s, and there are a lot of them out there. They are steeped in tradition, and have PG/TH350/TH400 on the brain. The truth is that they are just ignorant about the 700R4, and don't know how to make them hold up. They have probably built some in the past with either stock internals or the same parts they use in TH350s and expect the same results. 700R4s require a different approach, and different parts that have been designed specifically for the 700R4, not just parts that work well on a TH350 adapted to fit a 700R4.
You can easily buld a 700R4 to 575HP. You need a rebuild kit from Pro-Built www.700r4l60e.com
This kit addresses and fixes all the 700R4s weak links. It includes all clutches, steels, pump guts (10-vane), Vette servo, TransGo shift reprogramming kit, bushing kit, and basically everything you need. I am very, very happy with mine.
Old Jun 23, 2005 | 07:17 PM
dharrison's Avatar
Car: 1968 chevy truck, 85 z/28
Engine: 355, 355
Transmission: 700r4, 350turbo
how much does it cost??
Old Jun 24, 2005 | 07:55 AM
The kit is about $575, the Beast sunshell is another $90, figure $300 or so for a good converter (especially if you want lockup, they can be had a little cheaper if not). I rebuilt my trans myself, so labor didn't cost me anything. If I were to build one for a customer I think I would charge about $500 or so in labor. It's an intensive rebuilding/blueprinting operation to get the thing right.
Old Jun 25, 2005 | 09:26 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the beast sun shell should run around $40. that's the price i got my SPX filtran for.
Old Jun 25, 2005 | 05:12 PM
It's been awhile since I was on Pro-Built's website. The Beast sunshell is actually included in the kit. I was thinking about the replacement input drum that he offers as an option for $98. The kit is also under $500. Check out the site and the parts list. It's a hell of a lot for $500, especially with the shift reprogramming kit inlcuded. That's over $100 alone.
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
RednGold86Z
Nov 2, 2001 09:36 PM
