ATF in 9 bolt?
Old Jun 22, 2005 | 12:45 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
ATF in 9 bolt?
The original 9 bolt went out, (started to peg-leg) so I swapped it out for another.
I'm like 99% sure that all 9 bolts takes ATF, but when I pulled my cover, there was really really thick gear oil. I pulled the 9 bolt out of another thirdgen ('89), and don't know how long it's had the gear oil in there, but I had it in my other bird ('82), but I only drove it with that rear for probably less than 500 miles.
I should refill it with ATF right? And at work we use brakleen to clean out the rears when doing a diff service. Will brakleen hurt the clutches in the rear if they aren't already messed up? And what about additives? Any one use them? I read on the back of one it said not to use it with ATF.
BTW, both tags were still on the rear end.
Old Jun 22, 2005 | 09:24 AM
firebirdjones's Avatar
ATF?
I would not put ATF in the rear,,,even the 9 bolt. I have a 9 bolt in my iroc, the cover had never been off the car with 50,000 miles on it. I changed the grease recently, it had gear oil in it, as it should. ATF will not work, atleast for very long put gear oil in for sure. I didn't use any posi additives in mine since it is very quiet turning corners anyway, it works very well so a simple grease change is all I did. Hope this helps, Larry.
Old Jun 22, 2005 | 09:44 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
ATF will not meet the extreme pressure requirements of a hypoid gearset in a rearend. Use 75w90 gear oil or the like. Also, with a factory clutch type posi I always add the GM limited slip addative. Soem gear oil is formulated for use in limited slip rears, and theoretically shouldn't need the addative, but I always add it to be safe. I'm not sure about the 9-bolt though, because it uses cones instead of plates and clutches.
Old Jun 25, 2005 | 09:17 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Dont use the additive since the 9 bolt is not a clutch type posi. it requires friction to grip. NOW if it makes noise then you may need the additive to quiet that down, but I've never used it in my 9 bolt.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
