TH350 fluid capacity?
Old Jun 23, 2005 | 08:41 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I just rebuilt a TH350C from an 85 van. We took the conveter out and dumped out as much old fluid as we could get out.
Does anyone know how much fluid the TH350s take? Should you fill it half way and then start the engine for 20seconds first, or just put it all in?
I can't find the capacity of these trannies listed anywhere. Thanks
Old Jun 23, 2005 | 09:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
THey hold somewhere around 11 quarts, starting out dry.
If you're using a used converter, it'll probably take about 9 to fill it.
Put about 5 quarts in it before you start it; add 2 more as soon as you start it up; check it, fill up to Full, and top it off after driving it around.
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
89newfun
Sep 16, 2015 09:28 AM
