Clutch fork pivot??
Old Jun 27, 2005 | 12:23 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Clutch fork pivot??
Im having trouble with my clutch fork hitting my pressure plate while the car is running and the clutch is depressed. I have checked the t-bolt and it is tight, but the fork pivot has about 1/2 inch of slop in it, allowing the fork to contact the pressure plate. (I can see the wear marks on the fork and pressure plate) Has anyone had this happen before? Thanks in advance.
Old Jun 27, 2005 | 01:23 PM
TexasLT1's Avatar
Car: '92 RS
it happened to me but only because the T-bar bolt backed out some.
Old Jun 27, 2005 | 02:33 PM
Randy92Z's Avatar
Engine: Miniram 383
Yea TexasLT1, I did a search yesterday and saw your post about the T-bar on your car, so that did help me out and get me pointed in the right direction anyways, so thanks.
Old Jun 27, 2005 | 03:47 PM
TexasLT1's Avatar
Car: '92 RS
not sure what would happen, but my guess is the fingers on the release fork are not seated correctly on the ears of the throwout bearing. try pulling the slave cylinder, pop the clutch fork loose and let it hang, and see if the flats on the throwout bearing align with where the fingers would ride.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
mygta87
Sep 14, 2015 10:36 PM
