housing prep for rebulid
Old Jun 27, 2005 | 04:15 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I have a 10 bolt rear under constuction . Befor I took it appart I rinsed it whith kero and ran it , this worked nice . Now I have all the internal's out and there is some dabree in the tube's what can I do , can I spay any cemicales like break cleaner or degreser and then stuff the tube's with rag's and push through . Have air but I do not think this will cut it alone . Any do's and dont's Thank you for any help .
Old Jun 28, 2005 | 05:04 AM
ede's Avatar
ede
rags would work, you won't hurt it
Old Jun 28, 2005 | 01:51 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah. Soak some rags in brake clean and ramrod them through the tubes into the pumpkin. Keep doing that until the rags come out clean. That's what I do. If you want to get really fancy you can debur the inside of the rear with a die grinder. This will keep small particles from getting trapped by casting flash. Just make sure you thouroughly flush the rear afterwards. If you want a measure of added strength continuously weld the tubes to the center section.
Old Jun 28, 2005 | 09:46 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
to the both of you . TKO your PM was very helpful I bleive I am in the clear . The welding of the tube's I am a little unclear of . Is this when you get the brace's that connect to the dif cover and weld to the housing .
Old Jun 29, 2005 | 07:44 AM
If you look at the housing you will see that the tubes are made from steel, while the housing is cast. At the factory the tubes are pressed into the housing, and then plug welded. You can make the housing a bit stronger by running a weld bead around the tube and welding it to the housing. This will reduce housing flex by anchoring the tubes to the housing more firmly.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
