What code is for an '89 3.42 posi?
Old Jun 30, 2005 | 04:33 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I might be looking at one this weekend and I want to know exactly what to look for. I don't want the seller to trick me and I end up with another 2.73 posi, or even worse an open end rear.
Also, is there anyway to check out the condition of the rear end? I believe it's still on the car, but does leaking oil send a red flag?
Thanks.
Old Jun 30, 2005 | 05:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can look up all the RPO codes on the main page but they will only tell you what that car came with stock. Over the years anyone who had that car could have swapped gears which the RPO codes will not reflect. I doubt he will let you pull the cover and make a mess on his driveway so you may have to do the old driveshaft wheel count.
Old Jul 1, 2005 | 12:41 AM
Car: 1994 Trans Am
Aren't there numbers cast on the rear end? I understand the codes in the console, but those could be swapped out. I doubt anyone would swap from 3.42's to lower gears if they kept the rear end.
Old Jul 1, 2005 | 07:26 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The casting numbers will only tell you what rear end it is and not what gears are inside. There will be a ratio stammped on the gears inside. For a 2.73 a 41/15 should be visible. You can count the bolts on the cover to figure what rear you have without looking for any codes.
dbrochard
Jan 28, 2016 08:42 AM
codeysabatini
Nov 10, 2015 04:07 PM
Numbah-1
Sep 12, 2015 08:57 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
