Rear Axle Question??
Old Jul 2, 2005 | 05:15 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I am doing an engine swap on a 88 firebird V6
I have a 83' transam donor car. I want the rear disc brakes from the T/A. Some say the ratio is more disirable on the V6 rear end. Should I take the brakes off or take the whole axle from the T/A?
Old Jul 2, 2005 | 08:22 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what are the specific axle ratios? the t/a will "likely" have posi and the v6 "likely" won't
I would find out what axle ratio they both have befor anything
Old Jul 2, 2005 | 11:31 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
What he said. But most likely you'll want the TA axle, 1) disc brakes 2)maybe posi 3)may also have same gears, who knows.
Old Jul 3, 2005 | 05:54 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
How do I find this info out?
Old Jul 3, 2005 | 04:45 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
you can check out the numbers on the pass axl housing, on the front right by the pumpkin. or you can just take the cover off the rear end. you will see the posi and you can count the teeth on the gears.
Old Jul 3, 2005 | 10:56 PM
Engine: ls1, LB9
like 89 said pull the cover most even have the numbers on the gears stamped like (_ _ : _ _) well there will be numbers in there but, you get the idea just devide them and you will get ratio
Old Jul 4, 2005 | 01:07 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
The V6 will have a 3.42 open rear end.
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
