bell housing
Old Jul 5, 2005 | 09:19 PM
383firebird84's Avatar
Car: 84 firebird
Engine: 434ci
Transmission: turbo 400 3500 stall transbrake
Axle/Gears: 10 bolt 4.10 spool'd
bell housing
will a bell housing from a 6cyl fit a 8cyl will it work i know i need a new clutch and pressure plate what else do i need to make it work
thanks ryan
Old Jul 5, 2005 | 09:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No it won't work, the bolt patterns are different on the V6 and V8.
Old Jul 6, 2005 | 11:44 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Unless it's from a 4.3 V6 no. The 4.3 uses a V8 bellhousing (it's a 350 with two cylinders lopped off, as opposed to a narrow V clean sheet design like the other V6s).
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
