still have zexler 100 dollar units out there, or ?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
or whatever they are called, for the 7.5" axles with 3.42 ratio
do they still have them ? and for this price, or is there anything else out there for around same price and that is a posi unit ?
fit in open diffs and not require resetting lash/shims/pinion sleeve ?
thanks
thanks
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
I guess that you are talking about the Zexel-Torsen units. SLP used to sell take-offs from 4th gens for $100.
Now I would check Ebay or our classifieds for one. There's a new one on Ebay now.
I'm no expert, but if you change carriers, the rear end will need to be set-up.
Also the Zexel units are designed for 28-spline axles. Your '82 has 26. So you would be looking at an axle swap too.
sailtexas186548
Feb 17, 2017 03:07 PM
Denricci22
Sep 18, 2015 09:02 AM
Glowsock
Sep 5, 2015 07:48 PM
