10 bolt rear end
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
To do it correctly you need about $130 worth of specialized tools. You need a dial indicator (graduated in .001" increments or finer), a micrometer (accurate to .0005"), a magnetic base for the dial indicator, and an in/lbs torque wrench (must read down to 10 in/lbs).
A press and bearing seperators or pullers are very helpful, but not absolutely necessary. Check out www.harborfreight.com for cheap tools.
If you are going to do one rear I would say take it to a shop. If you're going to do ten I'd say buy the tools and learn to do the gear setup. It isn't that hard to learn, but think about your needs in the future.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
