Flywheel Dimensions
Old Jul 7, 2005 | 01:01 AM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
Flywheel Dimensions
Anyone know the Diameter of a stock T5 Flywheel ? also how many teeth.
Old Jul 7, 2005 | 03:57 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
ok i just found this on the search,
153
12¾"
so assuming this is the stock specs for a 86 and up t5, where can i find a flywheel with the same teeth and diameter, but with the wider bolt pattern, for the internal balanced motor, i belive which is the 1 piece main seal
also to give an idea of my problem, the motor is from i belive a 76-79 Camaro, so the flexplate that was in it was rather large, the flywheel i have wont fit the back of the crank being as the bolt pattern doesnt line up and the center hole isnt large enough, but i need the same over all diameter for it to work with the starter.
jmd's Avatar
jmd
Car: `86 SS / `87 SS
153 teeth (which uses a starter having parallel unequal length bolts)
clutch it takes is 10.5" (10.75" on 80s Vette pressure plate w/ special bolts)
Old Jul 7, 2005 | 04:04 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
ok so its 10.5 not 12 3/4 ?
any idea where i can get a flywheel that will work for me ?
am i correct in that the 86 and up used 2 piece main seal ? which was externaly balanced
Old Jul 7, 2005 | 04:09 AM
jmd's Avatar
jmd
No, 10.5" is the usual clutch disc diameter. Not the dia of the flywheel. You're overcomplicating this. For your pre-86 SBC, all you need simply is an 84 Camaro flywheel.
85-down SBC are 2pc seal with a neutral balanced flywheel (exc 400cid)
86-up SBC are 1pc seal with external balance.
Old Jul 7, 2005 | 04:13 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
ah ok i understand, sorry i had it all backwards in my head. so would this flywheel work ?
http://store.summitracing.com/defaul...4&autoview=sku
Old Jul 7, 2005 | 04:21 AM
jmd's Avatar
jmd
Yes it would work, but I personally would prefer a 16lb scalloped style flywheel, more commonly known for being used on the L69 thirdgen engine and the L88 427.
Old Jul 7, 2005 | 04:24 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
alright cool, thanks a lot man, you've been a huge help
Old Jul 7, 2005 | 04:25 AM
jmd's Avatar
jmd
no problem. that flywheel stuff can be at times.
Old Jul 7, 2005 | 04:27 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
yeah no kidding, I had everything i needed for the auto to manual swap, and i just got the flywheel resurfaced, then i got to put it on, and I was like oh hell no, so dropped the flywheel, went in the house for a beer. then the researce began :-/
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
