Do I need to recalibrate speedo for rear swap?
Old Jul 15, 2005 | 11:44 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I have '91 2.73 posi in the car and I'm swapping to a 3.42 posi (89 car). Do I need to swap speedo gears? Where do I get them and which one do I need?
What will happen if I don't get a speedo recalibration gear, will it make the car undriveable and add "ghost" miles?
Is it easy to change out, like can I do it after the install sometime, or does it have to be during the rear swap?
Ok, no more questions.
Thanks.
-Kevin
Old Jul 16, 2005 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Contact jmd on this site. He can provide you with the proper gears and info.
JamesC
Old Jul 16, 2005 | 10:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i thought the 91's had electronic sensor instead of the speedo gears.... but someone will chime in hear and correct that.
if not, go here
http://www.transmissioncenter.net/sp...n_______va.htm
i bought my speedo gears from here and used a 39/15 combo for 3.27's. they reccommend a 45/18 setup but that requires you to buy a whole new housing for the 45 gear.
for 3.42's they suggest a 45/17 combo but your gonna have to buy the housing for 45 gear
Old Jul 16, 2005 | 01:52 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
They do have electronic VSS's, but the speedo gears still need to be changed when doing a gear swap.
Old Jul 17, 2005 | 01:03 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
^ sweet, thanks, i wasnt quite sure
Jorlain
Aug 24, 2022 05:11 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
beachrodder
Aug 7, 2015 04:27 PM
