posi rear
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
posi rear
If i were to install a posi rear in an '86 trans am.. automatic 305.. what gear ratios should be used?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: posi rear
TGO welcomes you
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
It's hard to go wrong with a 3.73. 4.11 is a bit of overkill, and anything shorter won't give you the same seat of the pants feel. If you are concerned about milage then maybe cut it back to a 3.42. You've got overdrive though, so the difference in RPM isn't going to be that great on the highway.
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
My gas mileage was unchanged when I went from a 3.23 to 3.73 on my 350 crate. I say go with the 3.73s you'll be much happier, ESPECIALLY if you get a higher stall converter some day.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
