changeing rears
Old Jul 19, 2005 | 02:31 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
changeing rears
i may be picking up a 10 bolt for my iroc since i blew apart the 9 bolt that is currently in there.
my question is the 10 bolt is drum and i have disk brakes on there now. i will be getting the prop valve with this rear and i believe the brake lines are alreay on the drum rear.
so what is needed to be done to make this swap work?
will the drum brake lines on the rear attach to the exsisting lines on the car? also will the lines attach to the prop valve ok or am i gonna have to start making new lines also i know the e brake wont work or will it?
trying to make this as easy as possible since my time is limited on the space i am gonna be doing this.
im have changed rears before but those were direct fit never had to do the switching brake thing
thanks
Old Jul 19, 2005 | 03:01 PM
ede's Avatar
ede
connect the brake lines, leave the PV alone
Old Jul 19, 2005 | 03:28 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
wow sounds good i was getting scared of the stories i heard about changing fittings and the pv
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
BlackTopKing
Aug 19, 2015 12:13 PM
kyleb24
Aug 15, 2015 08:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
