Transmission rebuild?
Old Jul 20, 2005 | 04:03 PM
Kevin Knight's Avatar
Car: '82 & '84 Trans-Am
Engine: LG4 305 & L69 305 H.O.
Transmission: TH200C & 700 R4
Axle/Gears: 3:23 & 3:73 10 bolt
Can anyone tell me if it is easy to rebuild a 700-R4? I bought a rebuild manual for that model, and I am mechanically inclined, just need some reassurance, if it is relatively easy to tackle? Thanks.
Old Jul 21, 2005 | 06:02 AM
Pro Built Automatics's Avatar
The ATSG books will help here, and the video that is out there would be a good start. I carry all the necessary parts to make these last. Let me know if I can be of help?
Old Jul 21, 2005 | 09:16 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Re: Transmission rebuild?
I wouldn't call it easy, but it's definitely not hard either (if that makes any sense). I'd put it up there with an engine rebuild.
As long as you have a really good rebuild manual and a couple of special tools, you'll be good to go. Just take your time and be patient, and don't be afraid to ask questions. I've only rebuilt one 700R4 so far, and I would definitely do more if/when I have the chance. Good luck.
Old Jul 22, 2005 | 11:25 AM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
Re: Re: Transmission rebuild?
I'd have to agree with all that as well!
Lots O' patience is needed, as well as an extremely clean work area, no cat hair or dirt should be present for reassembly, and as "pro built" stated books and videos will be your best start.
dont follow what i did and end up taking the trans apart 2 more times because you forgot steel squigly spring that gets wedged inside, 3-4spring clutch springs werent replaced with improved springs .
I'd recommend this, first read and be able to understand the manual, take lots of pictures it will help should you forget how to reassemble anything, oh and label your parts in bags and where they go as you remove them. clean the vb with compressed air not a rag. and try to stick w/ one parts supplier, simplifys things later on or buy everything at once.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
devilschariot
Feb 25, 2016 03:08 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
