Speedo gear????
Old Jul 21, 2005 | 08:12 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
Speedo gear????
Does anybody know where I can find info on what speedometer gear I need based on tranny (700R4), tires (245/50/16), and rear end (3.23 posi)?
Old Jul 22, 2005 | 01:23 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I assumed it was cable driven. You have 3 options of combination.
15T Grey (8642620) Drive - 39T Brown (1359273) Driven
16T Blue (8640518) Drive - 42T Green (1362049) Driven
17T Red (8640517) Drive - 44T DK. Grey (9780470) Driven
Robert
Old Jul 22, 2005 | 02:27 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
RMK: Thanks for the info. Is there someplace on the web that has info listed for other tire sizes so that if I need it in the future I can find it? Thanks again.
Old Jul 23, 2005 | 03:38 AM
jimfulco's Avatar
Car: '72 Nova
Transmission: Saginaw 4-speed
http://novaresource.org/speedo.htm uses tire diameter & rear end gear ratio to find what speedo gear ratio you need.
http://tciauto.com/tech_info/speedo_gears.htm has a calculator for tire diameter and has a chart of available gears for different transmissions.
http://www.bgsoflex.com/speedo1.html may also be helpful.
Old Jul 25, 2005 | 06:00 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Thanks jimfulco, thanks exactly what I was looking for.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
