question on diff swap
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
orginally my car was stock w/ a 1988 2.8L V6 and 3.42 rear end. it now has a 5.7L V8 w/ the same rear end but I want to put in a posi. I've read that some things changed in '88 for GM rear ends and wasn't sure what would or wouldn't work. After lookin around and readin this is what I found....a 3.73 Eaton Posi Unit 7.625" 10 bolt GM 28 Spline..... and I know that Auburn has the same thing. Would this work in my '88 bird? thanks,
-Drew
-Drew
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
yours has 26 splines axles. you will need to get 28 splines to work the that carrier. Or buy a posi for 26 spline axles. gears are the same...
Car: 87 Camaro
Engine: 406
http://www.uspowertrain.com/axlesGM.htm This is a link to a chart with gm axles....should be all the info you need
Engine: Chevy 350ci
Originally posted by ede
edit: no point posting if you aren't going to believe me, i'll try not to confuse you in the furure by replying to your questions.
hey sorry man. i didn't mean to insult you. i've just been lookin around for that info for a while and was hopin you could show me where i could get ahold of it.
-drew
