Info on 700R4
Old Jul 31, 2005 | 10:36 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Info on 700R4
Is there anywhere on the web that has a picture of the 700R4 control valve body showing atleast the name of each of the valves or maybe the pressure test ports and which pressure is where. I've searched and it's easier to get info on casting spells than info in the internal workings of the 700R4. Plenty of rebuild info such as "remove the valve, check for broken spring or binding of the spool and reassemble". Nothing on what it actually DOES.
Old Aug 2, 2005 | 12:37 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The Haynes GM aut trans manual has a picture of exactly what you want.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
