posi needed for my 9 bolt
Old Jul 31, 2005 | 04:49 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i tested my posi by putting it in park,wheels off the ground ,stopping other wheel and the other does not spin (per 9bolt.com). but when i burn out only the right side spins. so i need new parts to put in a new posi for my 9 bolt. for some reason my emails to 9bolt .com do not go through.....does randy's ring and pinion sell the posi cones? does any one else know how to get a hold of 9bolt.com? phone number? any other sources for the posi for my 9 bolt? i have a guru that will do all the labor i just need the posi. the rear runs great no noises or leaks, just need the posi. thanks for your help.
Old Aug 1, 2005 | 03:39 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
i think u have to keep sending emails to miles (9bolt.com) because its a side job he does, but still thats no way to run a buisness by not responding to custumers. anyway i had the same problem with my 2.77 the posi was so worn, it would only sometimes work and that costed me some races so i got 3.27 disk 9bolt with a perfect working posi.
Old Aug 1, 2005 | 04:39 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
i cant believe there is no other source for the posi cones than 9 bolt .com... thats the kick in the balz. i got an email through.last night. i hope he responds..
Old Aug 1, 2005 | 12:14 PM
firebirdjones's Avatar
9 bolts
Although there is nothing wrong with my 9 bolt, I tried on several occasions to contact 9 bolt.com with no luck. I was looking to install more gear in mine, got tired of trying to contact him, plus since these are cone style posi's I decided this rear is just not worth my time so I am pulling it out as soon as I have a 7.5 10 bolt ready to go in. I can pick up Eaton pro series posi's for that all day long and they are easily rebuildable and much more durable to begin with. Then I don't have to worry about getting parts for the stinkin 9-bolt in the future. Larry.
hectre13
Dec 11, 2023 08:14 AM
IROCZ1989
Jan 24, 2016 03:55 PM
hectre13
Aug 26, 2015 08:17 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
