S10 bellhousing
Car: 83 z28
Engine: 305 for now
Transmission: 5 speed
S10 bellhousing
I have a 85 bird witha v65 and 5 speed, what i would like to know is if when i swap to a v8 and sag from a 83 maro can i just use a 4.3 litre s10 bellousing?, the motor going in is a 400 sbc with the factory biggar flywheel, and i was just hopin to save my self the work of either converting to the manual linkage that i got with the tranny, or having to find another flywheel and balance plate , and a t5 bellhousing. Thanks in advance.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yes a 4.3 V6 bellhousing is the only V6 bellhousing that will bolt up to the V8. Not sure about the flywheel though. It is probably only big enough for a 153 tooth flywheel. It's easy to check, just pull the inspection plate and see how much room you have from the teeth to the housing.
