slipping or line pressure?
Old Aug 8, 2005 | 02:02 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I just ripped the teeth off of some gears in my T5 so I took a 700r4 out of one of my parts cars to put in the formula. The parts car never ran when I had it so I don't know for sure if the tranny was good or not. Anyway i put in a transgo stick shift kit and all looked ok, no odd smells, very clean, no metal in the pan. I put the transmission in, hooked up the cooler lines and put 5 quarts of fluid in it. I started it briefly and then added more fluid, I kept doing this checking fluid with car in park and running until it was full (8.5 qts.) There is no leaks, but at six qts. the tranny would go into any gears. When I pushed it out of the garage with 8 qts in it, it finally went into first but moves very slowly. It will rev to 2 or 3k and then start to move. I was gonna drive it to see if it shifts but I decided to hold the brakes slightly to put the car under a little more of a load and give it some gas, it just reved up and smoke started coming out of the tranny. Could it be that I don't have enough line pressure somewhere and fluid is going somewhere it's not supposed to? Could the TC be screwed? or is the tranny just slipping?
Thanks,
Sorry for the long post
Sean
Old Sep 13, 2008 | 05:10 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
Re: slipping or line pressure?
ttt for you
someone972
Aug 30, 2015 12:52 AM
mike_c
Aug 27, 2015 04:32 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
