Need help with torque converter/flexplate combo
Old Aug 9, 2005 | 01:03 AM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I'm pulling out my turbo 350 tranny since I blew it the other night. the front pump is dumping fluid like a faucet. I'm rebuilding it with a TCI Pro Super Transmission Overhaul, the one they claim is used in their streetfighter tranny's. I also plan on switching over to a full manual valve body with reverse shift pattern.
I figured since all of this is going on I would go ahead and pull my hideously slow stock speed converter and put in a 2800-3000 stall speed converter. My thing is I don't know how many teeth or what bolt pattern flexplate I currently have. How do I figure this out? The tranny and motor will be out of the car.
Also if anyone can recommend a better rebuild kit for around the same price please do so. I want the tranny to hold 500hp.
Old Aug 10, 2005 | 09:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Measure the flexplate. 14" = 168 tooth, 12.75" = 153 tooth.
TH350's came with both the large and small converter bolt pattern. Measure from the center of the flexplate/converter to the mount bolt, double it - I don't know the measurement off the top of my head but if it's close to 10" I believe that would be the small pattern.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
