final rear end decision. tell me if you agree.
Old Aug 9, 2005 | 06:03 PM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
I've got a 1988 firebird. came stock w/ an open 3.42 rear end.
what i've decided getting was an:
Auburn Pro Series GM 10-bolt 7.5" 26 spline posi unit
about $440
and....
GM 10-bolt 3.73 Ring and Pinion set w/ a master bearing rebuilt kit
about $230
I think this should work i wanted to know what you guys though
thanks,
drew
Old Aug 9, 2005 | 06:49 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Why no 28 spline axle's for about 250$ more . Or is this all you can afford right now . If the rear is not busted now , I would hold out till I could do the hole thing with 28 spline axle's . With the kit you will have the axle bearings . All depends on how much power you plan on haveing .
Old Aug 10, 2005 | 11:59 AM
Engine: Chevy 350ci
yea i'm kinda tight on money but you as well as others have recommended the 28 spl axles, so i might hold off till i can afford those too. Though i've never had mine dyno tested, I can beat a Pontiac GTP rated at 265 horses so i guess mine is rated just above that. If that's on the verge of being too much power i'll wait a few till i can get the 28 spl axles.
got any websites where they sell the axles?
Old Aug 10, 2005 | 01:43 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
look into moser stuff, or strange. I saved up a lot and got a 12 bolt, but I am also planning on a load of power. What kinda power do you plan on shooting for?
Old Aug 10, 2005 | 06:02 PM
Engine: Chevy 350ci
i think that's about it for power. i rebuilt the 350 with all new mild-performance parts and a 4-barrel Holley 650 a year and a half ago. the only thing i reused was the block and crank. so as for makin it any stronger, i'm not in the budget cause i'm also workin on a off-road cherokee. for now my main goal on the firebird is to get posi, but i'd like to do it right and not halfass, thus being told i should get some 28 spline axles and toss the 26's.
Old Aug 10, 2005 | 09:07 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
You could look in to a stock posi unit from a newer f-body 89-92 with a 28 spline axles . Buy new ring & pinoin gears and new axle's . That should hold , I belive the ring gear is the week link in the 7.5 rear. I bought from Randy's Ring & Pinion www.ringpinion.com . I got yokon 28 spline axel's and 373 rinng&pinion gears. They are ouiet and beefy . Finding a good posi doner will be the toughest part , this will save a good amount.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
