700r-4 to T56
Old Aug 21, 2005 | 04:30 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
700r-4 to T56
I am considering a conversion from my 700 to a T56. Is there anything sinister that I need to know before I decide to start. If I do make the conversion, I plan on getting the whole car for the trans and motor, so I will have bell housing, shifter, clutch/pedals, etc.
Thanks.
Old Aug 21, 2005 | 04:40 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
do a search, alot of people did the conversion here, i read it and it was a VERY helpful site. its almost complete bolt in, need a new crossmember tho.
this is also a great site. http://www.skulte.com/T56.html
Old Aug 21, 2005 | 06:00 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
It's an easy swap, but make sure you've got a good amount of wrench time. If this is one of your first projects, seek a little help, there are some parts that can get you in trouble. If you've got any questions shoot them over. I did my swap in a day.
Old Aug 22, 2005 | 08:52 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Thanks. I have a couple of friends as well as a dad and brother who can help me with the mechanical stuff, but I may need some help in the technical department. Would you recommend to buy the crossmember or getting one built?
Old Aug 23, 2005 | 07:47 PM
Engine: LB9/383
You can't go wrong with the Spohn piece. It's a little pricey, but not worth the time to modify the stock one IMO
Old Aug 23, 2005 | 08:24 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Another question... How can I tell what the gear ratios are in the transmission?
Old Aug 23, 2005 | 10:22 PM
Engine: LB9/383
You'll have to either know what car it came out of and use the RPO codes to track them down or there may be a tag on the tranny somewhere and you'll have to cross reference the numbers either through GM, or a website. Most of them out of the f-body's were pretty much the same anyway so it shouldn't be hard to find out. ONly time you run into a problem is if it was out of a 'vette, which is unlikely since the case would be different.
Old Aug 28, 2005 | 03:06 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Will a 3.23 rear gear work well with a 2.97 first T56? I would rather have the 3.36 first, but they are hard to find and not as durable under power. The 3.23 rear would work well for top end/gas mileage, but what about off the line? I am still running my stock L03, I was wondering if there would be any differenvce 0-60 between the stock open traction 2.73 rear and 700R-4 and the new posi-trac 3.23 and the T56. Thanks.
I got these numbers when I added up the 1st gear and rear end ratios: 700: 5.79, T56: 6.2. But I don't know if that makes any real world difference.
Old Aug 28, 2005 | 06:22 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I had no issues running my 2.97 T56 with a 3.23 rear. I was running my old 2.73 posi right after the swap and that SUCKED.. No off the line power at all and 6th was useless unless you were cruising at 100mph (and then you couldn't go faster without going to 5th).
The 3.23 was night and day better. 3.42's would probably have been optimal, but 3.23's were real comfy
This was on my stock 305 TPI. Now that I'm swapping out to an LS1, I'll pretty much have to run 3.73's to keep the power band up.
Kevin D.
Old Sep 8, 2005 | 03:32 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Hey, I've been meaning to ask. What are your normal (not over revving, but at full throttle) shiftpoints now with the 3.23 and the T56? Thanks.
Old Sep 8, 2005 | 09:21 PM
shr00m's Avatar
Heh, I couldn't tell you! I had the T56 in for a month before I wrecked the car. Then I slapped the new rear in while putting the car back together after paint. I might have put 50 miles on it before getting a deal on a wrecked 2000 z28 I couldn't pass up.
I instantly started stripping the car back down to get ready for the LS1. Here's the T56 now, the day before Katrina. I finally got power back last night, so the swap is back on!
Kevin D.
Old Sep 8, 2005 | 09:34 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
nice
Old Sep 10, 2005 | 09:52 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Hey, is that TPI stock or have you modded it? Would you think about selling it?
Old Sep 10, 2005 | 12:05 PM
shr00m's Avatar
It's stock hardware wise.. The 305 setup and the T56 is for sale. Prefer to sell the engine as a complete package.
Kevin D.
Old Sep 10, 2005 | 02:07 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
PM sent.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
