transmission grinds going into 3rd
Old Aug 25, 2005 | 01:12 PM
chibe69's Avatar
Car: 1989 camaro
Transmission: 5 speed
my 1989 camaro 305 5 speed makes a grinding noise unless you double clutch it into third sometimes second???
Old Aug 25, 2005 | 03:29 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
And you question is??? What is it? How to fix it? What will it cost?
Probably a synchronizer.
Old Aug 26, 2005 | 10:34 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
3/4 slider could be damaged, which probably means the engament teeth are damaged on 3rd gear too. The synchro ring is probably fine. With symptoms like this usually the slider of gear are the culprit. This comes from too many shifts where the slider didn't fully grab the enagement teeth on the gear. Then the slider skips across the face of the teeth making a wonderful grinding sound. Eventually the damage is so bad that it won't shift into the gear without a double clutch or a very slow shift.
If you want to know cost to fix this send me a PM.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
