Does anybody know how to remove a B&M shift cable
Old Aug 26, 2005 | 08:25 PM
305Camaro84's Avatar
Car: 1894 Camaro Berlinetta 305 auto
Engine: 305 LG4
Transmission: TH 700 R4
has anyone here taken off your B&M shift linkage? i got it off of the shifter (it was binding so i got a new one) but i cant figure out how to get it off of the trans. thanks
Old Aug 26, 2005 | 09:23 PM
The Wizard's Avatar
Car: '85 Z28
Engine: 355
Transmission: TH350
First you have to unhook the end from the L shaped bracket. It usually has a cotter pin holding it on there. Then there are 2 big nuts holding the cable to the bracket that's mounted to your pan. Remove the one closest to the end of the cable then you can slide it out of there. You might have to remove one or both of those rubber sleeves to get it to slide through.......
Old Sep 28, 2005 | 08:00 PM
Engine: 305 LG4
cable
ok, the end of the cable nearest to the trans has a threaded end and it is almost impossible to thread out. do i have to remove the bracket to get it out?
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
