Shift Kit?!
Old Aug 27, 2005 | 04:23 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Shift Kit?!
How easy it to install a B&M Shift Kit Improver? I have a friend that said he would do it for $30 dollars but I'd like to do it if it's not that hard. I really want to do all the work myself on it!
Old Aug 27, 2005 | 08:03 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
The b&m shift improver kit is fairly simply to put im i dit it on a 700r4 for a friend in about an hour.
you have to drill a pasage in your valve body if you, replase the pressure regulator spring i think 2 or 3 springs in the valve body. and put the spacers in the acumulator.
I say give it a shot just take your time and if you have any questions ask ythe board. In my opinion the trans go shift kit is worth the extra money but the B&M will give you what your looking for better shifts. the trans go gives you springs for all the valves in the valve body.
GOOD luck
Old Aug 28, 2005 | 04:08 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
just did it on my th-350. started after dinner got it all rippped apart and put it all together the next morning. took no more than 1-2 total hours to do.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
