updrading rear end
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
updrading rear end
I have a 3.73 9 bolt w\disc brakes posi. I would like to keep the disc brakes. It is going out, about 120,000 miles on it and I think it is time. I want to know what other people have and what you suggest. Something that will bolt in directly, new or used.
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
You making a ton of power? If not then you can rebuild the 9 bolt or build a decent disk 10 bolt. Find a new carrier for the 9 bolt, all new bearings, seals and ring/pinion. Or find a 10 bolt and do the same. If you're putting good power to the ground, slam some aftermarket axles in a 10 bolt with a better than stock carrier. If you're putting serious power down or plan on running slicks, an 12 bolt is always nice.
Car: 1985 Z28
I dont have a huge ammount of power coming out. I pobably have an extra 50 hp. Does anyone have suggestions about what carrier to use, and ring\pinion.
Engine: LB9/383
Try to find a take out diff, SLP used to have them for $99 but when the Fbody production stopped so did that deal. They pop up on ebay. Whatever you do, stick with GM gearsets, they tend to be quieter.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
