Mini spool
Old Aug 29, 2005 | 09:59 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Mini spool
Does anyone make a mini spool for a 28 spine 7.5 rear end?
Old Aug 29, 2005 | 10:15 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Yes they do, but they are NOT made for drag racing. Full spools aren't that much more anyways. I had one made for a 8.5 and it lasted eight weekends. Got real sloppy. Not worth the while.
Old Aug 29, 2005 | 10:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've only seen listings for the 26 spline 7.5" and it's only designed for dirt track racing. They don't make a full spool for the 7.5". It's just not a strong enough diff for any kind of performance parts like that.
Old Aug 30, 2005 | 02:47 AM
CrazyHawaiian's Avatar
Car: too many ...
Yup I've only seen them for the 26 spline axles too. I think Richmond Gear makes one and the Summit Racing brand also makes one (talking mini-spools) both around $99. I'm gonna be trying these out with some extra 26 spline 10bolts I got laying around (dont mind if they explode), should be perfect for my application which is similar to dirt track racing/sliding, but on pavement with very little grip involved (lots of throttle, smaller tires then you'd use for roadracing). If you wanna do the install yourself stock car racing magazine has a nice writeup on the install with pictures (google it) ...
Old Aug 30, 2005 | 07:54 AM
BT283's Avatar
i just need a mini spool for temporary use because i dont wanna buy a $400 posi unit and bust it or just buy a 12 bolt in a couple of months, so who does make one for 28 spline axles
Old Aug 30, 2005 | 08:03 AM
Car: too many ...
This a daily driver?
Old Aug 30, 2005 | 08:05 AM
BT283's Avatar
Dont tell me im going to have to get the welder out!!
Old Aug 30, 2005 | 12:31 PM
BT283's Avatar
i found a mini spool for it but i am also thinking of going to just a stock posi unit, does anyone know where one is cheap? And also will a 93-02 posi unit fit in a 3rd gen? Thanks guys
Old Aug 30, 2005 | 08:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Yes and no. It will fit but the side gears will be for 28 spline axles. Only the 90-92 third gens have 28 spline axles. Since you have a 91, there should be no problems. Fourth gen 28 spline axles will not fit in a third gen housing. Neither will any other 7.5" diff with 28 spline axles unless it came from a third gen. ie, S10's, Astro vans etc.
Old Aug 30, 2005 | 09:01 PM
BT283's Avatar
I figured since mine was a 28 spline axle it would work, but i already knew that about the 4th gen axles not fitting in a 3rd gen housing, but why wont it? just wondering
Old Sep 1, 2005 | 01:08 AM
formula89383's Avatar
the axle rods in a 4th gen are like 2 inches longer per shaft, thats why my back tires stick out 2 inches on each side of the car. i did a full swap to a 4gen rear with a great posi and 3.42 gears for 300 bucks and i got better rear disk brakes.
hope that helps
Later,
Jon
cheesehomer
Dec 31, 2015 08:48 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
darwinprice
17
Oct 11, 2015 11:51 PM
09ave
Sep 7, 2015 06:03 PM
