91 rear axle side slop
Old Aug 30, 2005 | 10:07 PM
ckeene502's Avatar
i have an rear axle off an 91 z with a posi(stock). when i was looking it over i pulled on the studs for the wheels and there seems to be alot of movement in and out. could it be the c-clips?
i just want to make sure i put in a decent axle before going through the trouble of swaping the axle.
Old Aug 31, 2005 | 10:02 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If there's a lot of slop something is off. There will be a slight amount of play, but not much. Pull the cover adn take out th axels. Inspect the ends around the c-clip groove, inspect the c-clips, and inspect the cross pin. Replace anything that looks work or isn't up to snuff.
Old Aug 31, 2005 | 10:46 AM
ckeene502's Avatar
will do....thanks for the reply.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
BlackBoulder
Aug 11, 2015 11:15 PM
