Ws6 4.10s fit in a 92 rear?
Car: 1992 25th Anniversary White W/ Red
Engine: Procharged 383CI/ Soon LS2 Turbo
Transmission: Manual 700R4
Axle/Gears: 4:11/Auburn Posi/Moser Axle
I have a 2001 Ws6 rear end with 4.10's will they fit in my 92 rear end?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Everything is the same externally if you want to swap the entire diff. The fourth gen diff is 2" wider on each side so your factory tires will stick out.
Internally, except for the axle length, they're both the same.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Originally posted by Z28cross-fire
Yes, 87 and up (i think it's 87) they all have 28 splines until the final year 2002.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
I'llrocya
Feb 2, 2016 11:43 PM
hectre13
Aug 26, 2015 08:17 AM
