Is it gonna blow?
Old Sep 9, 2005 | 11:47 PM
aimless's Avatar
Car: 86 Z28
Engine: 400
Transmission: 5 spd
Is it gonna blow?
I'm putting a 400 in my 86 z, it was a factory 2 bbl 175hp 400ft lb engine. I've got a carter 625, high rise intake, an older performance cam and I shaved the heads a little and used marine gaskets for a little more compression. I don't know how much extra hp and torque I'll end up with. How long is the T5 gonna last? Oh yeah, it's now also got a s10 posi with 4.10 gears.
Old Sep 10, 2005 | 02:52 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It depends how you drive it. If you like to do 6000 RPM dumps your going to leave that thing on the pavement fast but if you take it easy if should last like its behind a V6.
Old Sep 11, 2005 | 12:25 AM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
unless hes built that engine up w/ really good internals then id say the engine will go just as quick as the trans if hes reving to 6 grand thats one bad thing about the 400 sbc it just wasnt built to be very high reving
Old Sep 11, 2005 | 01:20 AM
aimless's Avatar
Car: 86 Z28
Engine: 400
Transmission: 5 spd
I do plan to race it a bit, I don't know about 6000 rpm though. I thought those t5's were only good for about 250ft lbs torque...
92projectcamaro
Dec 8, 2015 12:25 AM
91 SrS
Oct 7, 2015 04:32 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Vincent135
Sep 28, 2015 10:50 PM
86IROC112
Sep 28, 2015 08:17 PM
