Tpi Transmission?
Old Sep 10, 2005 | 12:49 PM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
Tpi Transmission?
Does anyone have a TPI transmission in their ride? How would you rate it's performance? Do you think It's holding up pretty well?
Old Sep 10, 2005 | 01:19 PM
Car: 85 Berlinetta
Here is my story. I purchased a 700R4 built by TPI. It was supposedly built to handle 600HP. I put 265 miles of street driving on it to make sure it could hold up. And it did so very nicely. Then I went to the track. Long story short- there was a cracking noise in the transition from 2nd to 3rd. Fearing the worst, I limped it back home gently and pulled the pan down to find planetary shims in the pan & filter. I took the trans to a local repair shop who disassembled it and told me the trans. could not have been built to hold 600 HP, because there were ALL STOCK brown clutches in it and NO aftermarket parts at all. They didn't even use 5 pinion planetaries. No hardened input shaft, no Beast Sunshell....In fact, several parts were used like the valve body from 1982 (most undesired), and worn out like the TV plunger and sleeve and the 1-2 accumulator spring. These parts wouldn't wear out in this short of time. I'm just stating my story. I don't make 600HP, I don't spray, & I didn't even have slicks on. I'm just posting these facts as words of advice. Be informed about your purchases, and deal with local people you know and trust! Peace out!
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Dec 6, 2015 11:25 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
Sanjay
Aug 12, 2015 03:41 PM
