V6 & V8 trans
Old Sep 13, 2005 | 06:27 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
V6 & V8 trans
Are the V6 transmissions as strong as V8 transmissions would a V6 transmission handle the 350's torque? or would i need a transmission from a V8
Old Sep 13, 2005 | 06:38 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: V6 & V8 trans
No,V-6 trannies are weaker than a v-8,and if your talking about the T-5 5 speed,the V-8 version is barely strong enough for a stock 350
Old Sep 13, 2005 | 07:11 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
actually their the same strength. its just that the spline count is different and you'd have to get a custom clutch.
Old Sep 13, 2005 | 08:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Fewer splines means smaller shaft means less strength.
Old Sep 13, 2005 | 11:28 PM
7plagues's Avatar
yes well the internals are physically the same strength.
Old Sep 13, 2005 | 11:34 PM
five7kid's Avatar
Let's let this discussion continue on the Transmission forum.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
