TPI and TH350 kickdown
Old Sep 14, 2005 | 08:32 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Ok I just purchased the Lokar kickdown for my TH350/TPI combo. Just wondering if anyone as done this swap using this cable. I and debating on buying the nice mount and throttle cable to match, and would like to see a pic of it all together if someone might be so kind??
Kickdown Cable, part # KD-2350TP
Throttle Cable
Mounting Bracket for both.
Old Sep 19, 2005 | 02:06 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Wow I can't believe out of the thousands of people here that no one has used these cables??
Old Oct 13, 2005 | 06:53 PM
SatisTraction's Avatar
so did you try it? ia m swapping a TPI into my 85 truck and need some kick down help. the original carb one will not fit.
thanks
chris
Old Oct 13, 2005 | 06:56 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
From the pictures it should be a really nice looking piece under the hood but not sure about functionality.
Old Oct 13, 2005 | 07:02 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
thanks
chris
Not yet, as I am getting an LT1 intake to convert to my block, I did however line it up quick, and it should work great!!
The pictures don't do it justice to be honest, plus I will polish the hardware up to bring it to a mirror finish. It's only a TH350, as long as you set it up right, it will work as good as OEM, maybe even better??
stalkier
Dec 6, 2015 11:25 PM
LittleFranks
Sep 17, 2015 12:22 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
