Camaro 68 4 speed transmission ??
Old Sep 15, 2005 | 03:14 PM
mat89RS's Avatar
do i need to have a different driveshaft or crossmember, will the tranny fit the tunnel without major modification to the body ?
for the linkage, i can work something out, i'm a machinist.
Old Sep 18, 2005 | 06:25 PM
LT1guy's Avatar
Car: 1987 Trans Am
Re: Camaro 68 4 speed transmission ??
Which transmission is it? Muncie M20/21/22? Borg-Warner T10? Saginaw? All of them are about the same length, so the driveshaft for one will work for the others, but your stock driveshaft isn't going to be the right length. Spohn I beleive makes a crossmember for the 4 speeds, or you could make one. Not sure if the 82 4 speed crossmember will bolt up in your car (never seen one), but it probably will. The 82 4 speed driveshaft should work also. Fitting in the tunnel should be no problem, all the 4 speeds are fairly compact (compared to modern 6 speeds and aftermarket 5 and 6 speeds at least).
Old Sep 23, 2005 | 08:39 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Moved to drivetrain...
Old Sep 26, 2005 | 02:06 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Driveshaft will need to be lengthened.Longer than a T5/700R4 shaft.
It will fit in the tunnel just fine.Crossmember is different but you should be able to mod T5/700R4 x-member to work.
Check out the classifieds.I am selling a '82 T10 that will work with the torque arm and includes Hurst shifter and crossmember to fit in an f body.Came out of my '82.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
