700-r4 Won't shift at WOT
Old Sep 18, 2005 | 12:16 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Adjusted TV cable. Fluid level is proper.
350 in a suburban, with 35" tires.
Stock rear-end gears.
On the freeway when I'm cruising, if I go to WOT it will pull and pull, but when the speedo reads ~75mph, (actually more like 90 since it hasn't been calibrated with the larger tires) the motor sounds like it's spinning past 5-6K and it won't shift up to the next gear. I have to let off for it to shift. But when I am trying to go fast uphill, I can't get past a certain speed (speedo indicated 60-64mph) Any ideas?
THANKS!
Old Sep 18, 2005 | 07:59 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
What gear will it not shift into? If it will not shift out of first, it is likely a stripped governer gear.
Old Sep 18, 2005 | 11:43 PM
Pro Built Automatics's Avatar
If it won't make the 2-3 shift at WOT, then this is common on the 700R4. A Corvette servo & larger boost valves at a minimum will help this problem, if the 3-4 clutches are still in good shape. What rear end gear ratio are you running now?
Old Sep 19, 2005 | 04:20 AM
darrells3rdgen's Avatar
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
does the engine have a fan clutch?
if so the fan cluct can lockup and make the engine sound as if its reved to high while driving.
Old Sep 19, 2005 | 02:41 PM
nidyanazo's Avatar
Ya, 2-3 shift. I forgot about the need for a larger servo.
2.73 rear gears.
I'll check the fan clutch....
Old Sep 20, 2005 | 04:04 PM
Alex99's Avatar
I would definitely check the transmission pressures. I had the same problem and did change everything to high performance except the pump. Nothing could help really.
Finally I changed the pump and everything was right.
junior419
Apr 7, 2025 11:35 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
camarohelp
Sep 22, 2015 03:19 PM
Fronzizzle
Sep 8, 2015 12:10 PM
