T-56 from a 94 TA info please
Old Sep 21, 2005 | 06:44 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Ok so I just bought a T-56 from a 94 TA. I really need to get filled in on what all the connections are. I wish i was at home cuz then I could post pics. But oh well I will describe stuff as much as possible.
Is the electrical connection on the right hand side the speedo signal sending unit?
What is the big connection next to the shifter?
What is the hose on the top of the tranny, neer the middle? (vent?)
This has the same amount of splines on the shaft, so I can run my stock driveshaft?
Where can I get an aluminum driveshaft?
Where is the reverse light hookup on the tranny? (Left side, neer rear?)
And finally, what is the gear pattern, in other words where is the reverse? It is not in the car yet, and I know I could easily find out once it is, but can someone just tell me? Thanks everyone.
-Dennis
Old Sep 21, 2005 | 05:06 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Reverse is right and up, unless you hook up the reverse lockout solenoid connector the brake switch or another 12v source (momentary switch?) you have to overpower the solenoid manually which just takes a little extra effort, theres like a spring there..
I'm pretty sure the connector on the drive side of the tranny close to the shifter is for the reverse lockout.. Stock driveshaft will work fine, and you can get any 82-02 aluminum driveshaft.. You see them for sale here and cz28.com all the time.. If not you might try the dealer as a last resort but I don't know what they charge..
That's about all I'm good for I'm sure someone else will answer the rest
Old Sep 21, 2005 | 05:19 PM
Engine: LS3
Well that was a lot of info, Thank you. It is appreciated
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
