28 spline and spider gear
Old Sep 21, 2005 | 08:21 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
hello axle specialist,
My spider gears are worn out and one of my
axles splines is also worn down, I think this is what
is causing my wheel to wobble a bit.
my question is
Can I use spider gears for the 28 spline axle
and swap out my old spider gears which are for
26 splines axles?
If I could do that then I could upgrade to 28 spline axle.
Old Sep 21, 2005 | 08:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes and no. The 28 spline spider gears will easily fit in where the 26 spline spider gears are however the hole that the axle goes through in the carrier probably isn't big enough to allow the 28 spline axle through.
I tried this years ago. I was able to find a carrier that used 28 spline axles to fix the problem. The only other option is to have the hole machined out large enough to let the axles through.
Old Sep 21, 2005 | 10:39 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Thanks for that info
To bad that would of been cool if it worked.
IF I ever get my hands on a 28 spline axle Ill try
it out.
Old Sep 21, 2005 | 11:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I was using aftermarket 28 spline axles. I doubt a factory 28 spline axle would have worked either.
Old Sep 22, 2005 | 06:54 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Whats wierd is if you can get 28 spline pinion side gear
in the carrier one would figure that you could slip in that
axle.. just a thought
Old Sep 22, 2005 | 07:50 AM
AlkyIROC's Avatar
Car: 87 IROC L98
The outside hole of the housing is slightly bigger. I think the 26 spline housing has a 1" hole and a 28 spline housing has a 1-1/16" hole. The spider gears are on the inside and don't care about the hole that the axle goes through. GM just changed the casting slightly when they upgraded to 28 spline axles.
F-body driver
Mar 6, 2023 11:44 AM
Nick McCardle
Sep 10, 2015 08:36 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
