Where to get speedo gears -- removable plastic gear that goes on metal shaft
Old Sep 29, 2005 | 01:50 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have a T5 WC that I am using with a mechanical speedometer. I got a speedo housing and driven gear for this mechanical setup (it is the late style mechanical gear that has a metal shaft and uses the same clip on plastic gear that the VSS encoder speedo driven setup uses). Where can I get these removable plastic gears in different tooth #s? The gear I pulled was a 19 tooth. I am currently using an old style (60s-70s) speedo housing with the old 1 piece plastic gear, in a 22 tooth, and this gets me really close, but I'd like to use the later style metal/plastic 2 piece driven gear since it has a larger center register that matches the T5 tail shaft.
Old Sep 30, 2005 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check with jmd on this site. He'll set you up with what you need.
JamesC
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
3rdgenparts
Aug 8, 2015 07:09 PM
MENINBLK
Aug 5, 2015 11:58 PM
