TH350 noise...
Old Oct 5, 2005 | 02:21 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
TH350 noise...
I have a TH350, and it is making a noise. When the engine is cold, it does not make a noise. When the engine is warm, and I put it in drive or reverse, it makes a supercharger like whine, up until about 2000 rpm, then it stops. Before you say it is the pump, I will tell you that I just put in a 4200 stall converter and before that, it didn't make a noise. Also, in the process, I half kinked a trans cooler line. Is this noise related to the trans cooler line, or did I mess up the pump putting in the new converter? Or possably something else? I have driven the car this way for some time and there are no shavings or anything in the trans.
Old Oct 5, 2005 | 07:48 PM
REALPOWER's Avatar
Transmission: Th350
I read this on a website on converter intallation instructions...
"The 2nd most common complaint on converters is a whine after installation. This usually means there's too much clearance between converter pads and flex plate.(Washers needed between flexplate and converter) This draws the converter hub too far out of the pump drive gear causing the gear to rock.
Has anyone experienced this?
Old Oct 5, 2005 | 10:41 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if the gear is rocking in the pump, you have too much clearance already, which means the pump will not last long.
Old Oct 6, 2005 | 11:24 AM
REALPOWER's Avatar
Transmission: Th350
Maybe I'll throw a few washers on the flexplate and see if it helps. Funny, it wasnt doing this before...
Old Oct 16, 2005 | 09:23 PM
REALPOWER's Avatar
Transmission: Th350
Threw washers on the flexplate to space.... made noise worse. Diagnosed as bad torque converter.....
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
